I have one of these, although mine was bought new in the States in the 'seventies. I've never needed to use it!
Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
Haven’t got a clue
Clue: The pale grey bit is a hollow tube.
I too think this is a later iteration. The example shown was in use in the sixties on small round sealed cans of oil, as refillable bottles were being phased out.
I have one from the teens and twenties, it is a brass and steel stirrup that lodges under the corner of the 4 gallon square tin can. There is a handle which presses the spout into the top corner. These tin cans came as a pair in a wooden box for delivery into parts of the country where there was no pumped fuel supply.
When I worked in a gas or service station as a teenager these were used to pierce 1 quart cans of oil. The spout was then used to pore the oil into the crankcase. Oil cans at the time were constructed of thin sheet tin.
Looks like something worn in a Shakespearean play!!
