14-11-2018, 12:25 PM
(This post was last modified: 14-11-2018, 12:30 PM by Bob Culver.)
Post war Minxs had this arrangemnt. The manual places considerable emphasis on the correct clearance of .0015 on both internal and external surfaces.
I trust the conversion suits all situations, including lowered oil level. The situation on racers may actually be less onerous than road cars which can toil up hills in 2nd for mile after mile.
The modification was common on Jowett cars but with 60 bhp the bearing usually emerges looking distressed.
I take it the cones are old ones worn smooth. If considered worthwhile, the grooves can be tediously cut with a fine square edged tool, but the edge of a fine thread tap is much quicker.
Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
Made the same error yesterday . Made a puller. Wooden one did not work. Even though the unit was turning
The problem is not the bush, when a new c/ratio gear is fitted to the 1st motion shaft they are pressed on and welded in place this can shrink
the bore of the 1st motion shaft so the bush will go part way in and then go tight. Some need a light polish to the bore to give clearance
or you may need to grind the bore out with a small grinding point while rotating the gear as its the far end of the bore that shrinks the most
then polish with a small emery drum. I have had to do this to most of the c/ratio sets I have fitted.
Terry
Thanks guys, have arranged to visit Steve tomorrow for another pair of eyes and some engineering knowledge to help me out. It should have been obvious to me, thinking back now, that the grooves on the outside of the bush indicate there should be clearance there too. Will report back later.
I got the bush out easily enough and tested it on the shaft and in the old 1st motion shaft and it runs freely on both so yes, it seems the CR one has shrunk and definitely more closer into the gear where the heat would have been as Terry says.
Removal of just the taper by internal grinding is a tricky operation. If you turn up test plugs, can the bore be corrected wih a single stone from a brake hone or a piece of half round slip stone, pressure applied at one end with a stick or suchlike?
Clearance on outer surface sufficent to tolerate heat expansion would seem essential.
