I now have a nicely machined replacement crank. Crank case measures within 1thou for c/m alignment (with block&head bolted on). So the engine is now going back together.
I have a concern over using an oil pump cover plate gasket though. There was one fitted originally, but it was torn by the rotation of the pump and it's vanes. This leads to excessive clearance and high likelyhood of gasket material being pumped through the engine - which is far from ideal and will also mean high internal pump leakage and low pressure/flow output. I consider it probably better to not fit a gasket here as the surface and are good and very flat and will seal well. What's the collected view on leaving the gasket out?
Ray
I don't think there is such a gasket.
There is a gasket between the pump body and the crankcase, and in the parts list I use this gasket is drawn as if it goes between base and body, but it does not.
Simon
Simon is correct - the oil pump cover does not have a gasket, although I have dismantled a number of engines where one has been fitted as you describe.
Ideally you also want to face the cover plate so that it is perfectly flat, they often have a circular wear mark...
Thanks. Didn't seem correct that a gasket had been fitted there previously....
Hi Mr f,
I would suggest before putting the crank into the case you assemble the centre main onto it and make sure it turns OK. Although it seems blindingly obvious now, I've recently discovered the hard way, that individual bearing housings are not directly interchangeable. If your pair come from a previously running engine you should be OK but if not better to know before the engine's too far built? You can bolt them together roughly with two 3/8BSF x 4" set screws, the shells centralise the two halves together. There would be no harm in also trial assembling the big ends to check they're free as well, which leads onto doing a rod straightness check with a king pin through two adjacent little ends 1 to 2 and 3 to 4.
Dave
