11-11-2018, 04:47 AM
I have always thought of the Chassis nosepiece as a forging- but see it regularly called a casting - is there any Longbridge factory specification available ?
Steel forging or steel casting
11-11-2018, 06:09 PM
Where have you seen it referred to as a casting?
Colin
11-11-2018, 06:15 PM
11-11-2018, 09:13 PM
(This post was last modified: 11-11-2018, 09:15 PM by Tony Press.)
11-11-2018, 09:42 PM
Thanks, found it on page 18. (Says the cast nose piece is an example of excellent design, efficiently doing ten different jobs since so much bolts to it.)
Colin
15-11-2018, 10:47 PM
15-11-2018, 10:54 PM
(15-11-2018, 10:47 PM)Tony Press Wrote:(11-11-2018, 09:42 PM)Colin Morgan Wrote: Thanks, found it on page 18. (Says the cast nose piece is an example of excellent design, efficiently doing ten different jobs since so much bolts to it.) I honestly don't know but I would have thought it should be a forging; purely from the point of view of strength.
15-11-2018, 11:45 PM
I hoped this (below) might answer your question Tony, but I'm afraid not.
@ 6 mins though you can watch an A7 crank being forged... ("Through the mighty beating of 36 hammers, whose reverberations are heard on a still night 2 miles from Longbridge"). https://www.youtube.com/watch?v=-kcMaoGA-HE
16-11-2018, 05:06 AM
As ever, the factory shots very interesting. Esp the cranks. I don’t suppose Phoenix stomp them out quite so fast. Presumably the frenetic pace everywhere was not maintained. There must have been many accidents. And fumes would take a toll. No safety glasses.
For anyone that may be interested, steel casting was/is not widely used. There was a more expensive version of Record vices in steel rather than high strength iron. Included in the wording on side. I understand Ford 10 and V8 cranks were cast steel. The frames for American steam locos, bogey frames, and the turrets and bodies of some tanks cast steel |
