Any idea who this is ?
[img]blob:http://www.austinsevenfriends.co.uk/33d9274a-4c1b-4ff6-b5ba-e437959e2d22[/img]
Sorry didn’t make a good job of yhst
(04-11-2018, 11:13 PM)Derek Sheldon Wrote: [img]blob:http://www.austinsevenfriends.co.uk/33d9274a-4c1b-4ff6-b5ba-e437959e2d22[/img]
Is it because you put / in front of the second img ?
Tony the img brackets are correct the / is to signify a close (to make it easier to see beginnings and ends if you have a lot of code).
Derek the issue is that the link is to a page rather than a file. Usually if you right click an image (assuming PC) and open in a new tab the address at the top will be of a file, and will end with .jpg or some similar file extension. Unfortunately trying to follow the link to fix it I get a file not found error?
If you let me know where to find it, I can try to get the image up for you if you want.
Got it this time, sorry it’s on it’s side
[attachment=4374]
(05-11-2018, 03:38 PM)Derek Sheldon Wrote: Got it this time, sorry it’s on it’s side
On its side Derek?  You've put it the right way up!
Well spotted Martin, now easier to read the registration
XVV 315 isn't on the A7CA Chassis Register but is taxed until August 2019. I think XVV is an age related plate dating from August 1979 when the car was 'first registered' according to the DVLA database.
For easier reading.....
.jpg   A7.jpg (Size: 68.26 KB / Downloads: 407)
Nothing wrong with that Mr Fawlty. Lick o' paint, one hour...
