Alternative use for a brake drum
I've been struggling getting the steering wheel off my traction engine.
Its mounted on a tapered square and was pulled onto the taper with a 3/4 whit nut. So it was pretty tight.
The wheel is cast iron too, so I was keen not to break it.
Its a difficult thing to use a puller on. After a bit of thought it dawned on me that a modified brake drum would be ideal.
I also had to grind the wheel mounting lugs off to. But I was successfull.
[Image: 008_1697.jpg]
[Image: 008_1698.jpg]
[Image: 008_1699.jpg]
It will make the brakes on the seven a bit lumpy when you use that hub wouldn't it ?
like it!
If you'd cut through between the wheel stud holes it could have doubled up as a brake lining clearance checker.
C
So far everyone has missed the most important point. . . . . . .
You have a traction engine!!!
How cool is that  Big Grin Big Grin
And a steam roller!
