Bicycle speedometers
(18-09-2017, 09:13 PM)Ian Williams Wrote: Alan, if the don't work on 6V you could probably use one of those little step up voltage converters, small and cheap.
As discussed with GPS/Sat Nav. - use a cigarette lighter socket direct connected to the 6 volt battery and insert the plug. This  seems to work for most.
Cheers, Tony.
Thanks guys, I will try one.
