1932 Austin7 RP rear spring "Rebound " Rubber
Hi, Whilst grovelling under the back of the RP, I have just noticed What I will describe as a Rebound Rubber Block attached to the chassis directly over the Rear Axle.  One of them is missing.
Can anyone advise what the purpose of this is,(probably obvious from my description), what is the correct description and are they still obtainable. ?
Smiley
Rubber "Bump Stops" is how I have always described them - I think you know the purpose. When the spring(s) travel beyond their normal limit, these Bump Stops prevent the axle and or the tyre hitting the bodywork.
Bob
These are available from Seven Workshop B0541
Hope that helps.
(18-09-2018, 06:04 PM)Nick Turley Wrote: These are available from Seven Workshop B0541
Hope that helps.
See here: https://www.theaustinsevenworkshop.com/p...bump-stops
Hope that helps.
Thank you all for your replies.  I will now purchase 2 and replace the 1 that is still there.
Smiley. Big Grin
(18-09-2018, 05:49 PM)bob46320 Wrote: Rubber "Bump Stops"  is how I have always described them - I think you know the purpose.  When the spring(s) travel beyond their normal limit,  these Bump Stops prevent the axle and or the tyre hitting the bodywork.
Bob
Hi bob46320, Thanks for your reply.
