18-09-2018, 07:53 AM
Manufacturing marks or wear?
18-09-2018, 08:30 AM
I don't know for sure, but that looks like machining marks made during manufacture. I cannot see how it could be wear related.
18-09-2018, 09:12 AM
Hi Ruairidh
Have you counted them and perhaps they Match with the gear teeth? If so perhaps the gear cutter was having a fag? Bill G
18-09-2018, 10:58 AM
They look like Broach marks where the gear cutting broach has been allowed to over run slightly. Not very attractive, but nothing to worry about.
18-09-2018, 11:53 AM
I noticed these on the Cup's clutch last week, they were not all the way around tho, only on the one side, i will try and get a photograph tonight before i put the box on.
18-09-2018, 12:27 PM
The markings look fresh compared to the rest of the plate...
18-09-2018, 01:29 PM
Looking at the striations and shape of the marks they appear to be identical and relate to the number of splines on the shaft - is there a gap where the blind spline should be? They do look recent but that might just be a trick of the light. You've not been cleaning the splines up with a 9" angle grinder have you?
18-09-2018, 02:08 PM
18-09-2018, 04:09 PM
I'm struggling to imagine what could cause a wear pattern like this. I'm with reckless, looks like someone has tried to clean up the splines with an angle grinder...
18-09-2018, 04:21 PM
Are the marks in line with the teeth or the valley between? Could the clutch plate come back far enough to chatter against the gearbox primary splines?
