Car type: Ruby mk 2
Hi people
Me again could anyone help with specifications of 1936 Ruby clutch pedal.
Or the length of the pedal would be useful.
Regards
Tim
26-07-2018, 07:02 PM
(This post was last modified: 26-07-2018, 07:03 PM by GK5268.)
It is to the same design as the brake pedal, but shorter with an overall length of approximately 125mm - face of pedal to tip of shaft. Secured to the pedal lever with a bolt.
Car type: Ruby mk 2
Many thanks Gary.
I guess the 125mm is mesured along the curve?
I was was going to use the same arc as the brake.
Regards
Tim
