05-07-2018, 12:15 AM
(This post was last modified: 05-07-2018, 12:18 AM by Tony Press.)
(04-07-2018, 12:48 PM)squeak Wrote: Whilst on the subject of front cotters , I make my own, about 3 inches long and jutting forward, with a light extension spring between the cotter and backing plate. This to help the brake shoe springs counteract the weight of front cable and fittings. cheers Russell
An article I wrote for our 'The Light Shaft' Club Magazine in 2010-
Front Brake Return Spring by Tony Press.
With the Austin Seven front brakes, there is often a problem with making sure the levers return fully to ‘off’, to prevent the Brakes from dragging when turning.
One way to assist with this is to add a short external tension spring to the brake lever, one end hooked around the neck of the ball end of the Brake Lever, the other attached to a hole drilled in the backing plate.
Another better way is to make up a special 3 1/2" long cotter pin.
A piece of 5/16” dia. rod about 4” (102mm) long is turned eccentrically one end and threaded ¼” BSF with a filed taper flat like the original cotter pin. The outer end of the pin has a couple of flats filed and a small hole drilled to accept one end a ‘pull of’ tension spring about 4” long. The other end of the spring is stretched up and inserted in a hole drilled in the backing plate. You will have to experiment with the spring size, length and position to get a good return tension, but not so tight that the front brakes are difficult to apply.
This modification was fitted to my Chummy in the 60’s and is still in place
If you look closely, this ‘return’ system was also used on my Austin 7 chassis on the Club Website History pages.
http://www.austin7club.org/Tony-Press/target4.html
It is interesting to note that in the late front brake shown above the lever has a twist at the ball end making the levers left and right handed which change appears to have been introduced around 1936.
Tony.
