Crankcase bearing lip repair
Anyone know where I might get a crankcase front bearing lip repaired? It is a 1928 magneto engine.
Many thanks, John
Ian Dunford , see cherished suppliers
We are able to repair coil crankcase lips Nigel but not magneto crankcases at the moment Nigel, thank you though.
I am going to want two spring shackles redone for my RN (going to look for a pair at Beaulieu in a couple of weeks ) who do I send them to Ian or You ?
I believe Seven Workshop will have these in stock very soon Nigel.
Thanks Ruairidh, I have emailed via your website so ignore that. Anyone else you could suggest that might help me? Surely it’s not scrap?
Hello John,
                      I can fit a steel replacement ring for the magneto engine  Pm me if you are interested
        Regards,
                          Robert
Thanks R , in which case won't look for old ones, I will wait until Jamie lists them.
(19-06-2018, 07:37 PM)jboy964 Wrote: Thanks Ruairidh, I have emailed via your website so ignore that. Anyone else you could suggest that might help me? Surely it’s not scrap?
Could try Ian Bancroft?
Thanks Robert, image attached of damage.
John
