10-06-2018, 09:18 PM
Can we have a picture of the boot lid/hinge problem please, how were they fitted originally?
10-06-2018, 09:25 PM
The boot is being worked on just now Ian, I am keen to hear how others building similar have solved the hinge. It is a simple affair, just two.
Many thanks.
10-06-2018, 09:37 PM
Presumably they are attached to the alloy skin and you need a backing? That could take the form of a block of shaped wood which I guess is how they were done, or a shaped piece of steel with some threaded inserts riveted inside the skin, you have probably thought of both these which is why I am intrigued by the problem, is it more complicated than I am imagining?
10-06-2018, 09:53 PM
They are attached to wood in the tail and the boot lid cover Ian, nothing complicated or fancy whatsoever. There is not really a problem, just tapping for some previous experience.
There are a number of Forum users who have built up Cup models and I am keen to know what they used, many thanks.
11-06-2018, 06:39 AM
11-06-2018, 08:02 AM
Thank you Peter, can you remember where you got them please?
11-06-2018, 08:55 AM
PM sent!
11-06-2018, 10:43 AM
(This post was last modified: 11-06-2018, 10:46 AM by AllAlloyCup.)
A pal at the local Men’s Shed sold me these hinges for £10 Which he had leftover from some work on his Church Hall. Very, very solid brass so may plate them Nickel with my home plating outfit. Not original I know but stronger than most. Regards Bill G
11-06-2018, 12:32 PM
Thank you Bill.
11-06-2018, 01:27 PM
If it's any interest to you, that design is called a Parliament hinge and from memory Screwfix do them in stainless steel
for about £15. |
