29-05-2018, 09:24 AM
(29-05-2018, 08:29 AM)BTony Press Wrote:(28-05-2018, 03:54 PM)Charles P Wrote: I use late type levers, with the hammerhead, and a four speed release bearing on a 3 speed engine and gear box. No problems. And no, I don't bother with mousetrap springs.
I know of a number of other people with the same set up. Much easier on the release bearing because it's not always revolving.
Charles
Not sure how you can be sure the clutch bearing isn't being turned by the levers flying out without the mousetrap springs to hold then in place- or possibly even worse the levers are sliding around the bearing.
Tony.
It's never been a problem, so I don't worry about it!
Charles
