Austin Seven max weight?
#21
I always thought the problem with putting a wire-wheeled car on brake rollers was not while testing, but was the harsh drop into the rollers before testing.
Oliver, I've just sent you a PM.
I don't see that there's anything a rolling road can do to an Austin Seven wheel that just driving around won't be doing all the time.
Not done a lot of trialling, Andrew?
Hello friends!
Well, 40 stones or 250 kg... I will try to get this data accepted by the transportation office.
Thank you very much for your inputs.
Best,
Oliver
