Whats the vertical clearance of the rings in their grooves Malcolm? I ask because I've just had a similar experience with an engine that's only done 10,000 miles and the top ring has 0.012" vertical play and guzzled oil a sure sign of ring scuffing leaving the ring corners like razor blades whilst another car has 60,000 miles on the clock and doesn't seem to burn any oil.
Dave
I have just checked the pistons and I can get a 0.012" feeler in above the top piston rings but only if the rings are proud of the groove.  Logic suggests that the rings may be tapered?
By luck I have found a tin of new old stock piston rings in my spares so I am thinking of replacing the two upper rings on each piston.
Hurrah, PWA7 Magazine arrives. Hmm, no sign of a membership card contained therein.
Josie dressed up for VE Day with a union flag painted by my father for the queens silver jubilee!
.jpg   IMG_0511.jpg (Size: 71.99 KB / Downloads: 57)
Hi All
Look what I spotted on our walk today  Big Grin
.jpeg   IMG_5098.jpeg (Size: 198.85 KB / Downloads: 21)
PS SO 08151 60520 is the Grid reference if you need a steering box ?.
Users browsing this thread: 36 Guest(s)
