Leaking Ruby Sunroof
I had a similar problem with mine, so cut a strip of old inner tube, removed the trim strip at the back end of the room and screwed it back in with the strip of inner tube facing upward and that sorted it!
Finally, back on-line after house move. It has been sunny all week so I haven't been able to properly test the pacamac suggestion in anger - I did try it anyway and it seemed promising - came home dry.
No, I never hear the last of it - the only place the Ruby roof leaks is at the back of the sunshine roof on the nearside - drips down the back of my wife's neck. I thought I had cured it by REMOVING the rubber strip along the back that appeared to be ducting the water in. After a promising start - three months of no leaks - it is now as bad as ever - even when it hasn't rained for weeks.
Has anyone - or anyone you know - recently claimed on Pytchlyy's no qibble, lifetime Warrantee, I wonder?
