After some winter renovation i had my first drive in the chummy on Saturday - It was both glorious and horrendious all in one! I now have a nice list of jobs to work through - Thanks to everyone who has offered help and advice to get to this point.
Hi John
To misquote Michael Cain “You’re not supposed to blow the doors off”.
(04-03-2025, 01:31 PM)Howard Wright Wrote: Hi John
 The amount of smoke that was billowing from everywhere bar the exhaust you would think that there had been an explosion!!
It's been eventful today.
I started off in a bewildered state planning to go into Galashiels to get a printer cartridge and get petrol on the way.
half way to the petrol station I realised I didn't know what cartridge I needed, so had to return home for the information. I then set off again intending to go to the petrol station on the Melrose bypass at Tweedbank. However the Austin is used to going a different way over the old Lowood bridge and took me that way. On the hill up from the Tweed the petrol ran out. I knew it was low but enough to get the the intended petrol station if there had been no diversion. I put in the spare gallon I always carry and then went on and completed the mission.
As I was driving I realised a brake was dragging - rear O/S, The hub was hot. I returned home using the hand brake as the rear brake didn't release.
I have now freed the seized brake cam on the rear offside. It was absolutely solid. This keeps happening and I'm not sure why. I replaced the cams and bushes (Oilite) failrly recently and know they are good. After lubrication, heat and hammering all was freed up, lubricated and reassembled. I hope they stay free. I expect using the car all year round does tend to make these thing happen.
I have various trips over the next 2 days so I hope it will perfom well. Dragging brakes limit velocity.
As we all know, left to its own devices over an extended period, the brake system defaults to leave only one working - the OS/rear. Might it be that the heat built up was enough to fry the oil in the oilite bush, which then caused the seizure?
One of our members showed me this photo is on a railway bridge in Hale which has had traffic light controlled traffic light controlled one way system over a railway bridge for the last 3 months with no apparent activity.
.jpg   IMG_0934.jpg (Size: 265.13 KB / Downloads: 143)
But why do they always put these signs on the footpath? How are we meant to walk home when the 7 let's us down?
Taking it easy..
.jpg   IMG_0934-2.jpg (Size: 400.87 KB / Downloads: 89)
Nah, the yellow sign shows a man not even pretending to work.
Users browsing this thread: 23 Guest(s)
