Value of Resistor in 6 Volt Cut Out
I have checked and I have a C35M dynamo fitted now. I have read that this needs a separate resistor (field?), but I am unclear whether this is in addition to the two in the cut-out or whether it is in addition to those.
Can anyone clarify for me, please, as I am getting confused.
Thank you.
Jamie.
Hi again Jamie
To the best of my knowledge, the early C35A had the field resistor in a little casing on the dynamo, to suit early cut-outs with no resistor.
The later C35A used a resistor inside the cutout. The C35M (Late Ruby) also had the resistor inside the cutout.
Some cutouts had two resistors, which could be used for 3 different charge levels. This facility was not used by Austin, so both resistors are used in series. If you want to use a modern resistor, I would suggest a value of 2.7 Ohms and a rating of at least 3 Watts. A metal bodied (gold coloured) type is convenient, as it can be bolted to some convenient metalwork to act as a heatsink. These are usually rated at a higher wattage, but that is not a problem
(14-02-2025, 09:33 AM)John Cornforth Wrote: Hi again Jamie
Thank you, John.
May I just confirm that this 2.7 ohm resistor goes across the F and D terminals of the dynamo and is in addition to the 2.5 ohms and 0.5 ohms resistors in the cut?
Jamie
Hi Jamie
No, you only need one resistor in the system, of about 3 ohms.
It doesn't matter whether this resistor is mounted within the cutout, on top of the dynamo or somewhere else. It always electrically connects between D (The output of the dynamo) and F (The input to the field coils). This supplies a low current via the resistor to the Field coils for Summer charge rate.
When you need Winter charge rate the resistor is shorted out by a switch so as to increase the field current and thereby increase the dynamo output current. This switch may be within the PLC2 Lighting/Charging switch, or may be a separate on/off switch if for some reason you are not using a PLC2.
(14-02-2025, 02:44 PM)John Cornforth Wrote: Hi Jamie
Thank you, John.
That is really helpful, clear and simple. I some nichrome wire, so shall see whether I have enough for the resistor. If not, I shall buy one. I shall be using just a normal switch as I have none of the original electrics or switchgear.
Regards,
Jamie
Thank you for the help with this question. I have fitted a wire-wound 2.7 ohm resistor. It was 3 but I snapped the end fitting it. I retained the Schottky diode as the smart diode that I bought looks very delicate and has no way to fix it down. The Schottky is much more robust and has a screw lug attached.
Jamie.
