Leaking Ewarts Tap
I need to fix my leaking tap.
Does anyone know of a decent secondary tap I can fit in place of my current offering?
The original tap leaks out of the carburettor.
I’ve stripped the tap once and cleaned it out, I think it’s still using the cork seals.
I’ll have another go using viton seals.
If that doesn’t work I need a decent tap.
Thanks.
Richard.
A good plumbing merchant would stock a female to male ball valve that you could be installed under the original if you insist on keeping that and then your copper tail attached, or extended to the carburettor
Users browsing this thread: Colin Ayre45, 3 Guest(s)
