source for taper pins
Hi All,
I'm on the hunt for taper pins for the gearbox levers which push on the bearing carrier to disengage the clutch. I've asked a couple of cherished suppliers who don't have these. I'm having some difficulty finding them here in the US. I think they might be No. 3 taper pins about 1.25 inches long. But I don't know what size the small end should be or how to determine the taper. The Austin part number is BH 85. As well, I need to source the washers/spacers which go on the lever shaft. These are part numbers BH87 and BH88.
Any sources are much appreciated.
Erich in Mukilteo
Eric,
You may find at least part of your answer here:
https://www.austinsevenfriends.co.uk/for...n#pid71860
Thank you, Chris. That's a start. But I don't know the specs. I think they are 7/32 so I think that would be a number 3. And I think the length is 1 1/4 inches, but since they are both buggered, I'm not exactly sure. As well, I don't know the diameter of the small end so unsure on exactly what I'm looking for...I've tried wiring the Austin Works at Longbridge and have yet to reieve a reply. ;-)
Erich in Mukilteo
I find Simply Bearings are pretty good for many of these mechanical parts
https://simplybearings.co.uk/shop/Engine...Taper+Pins
Not sure how their service stacks up in Washington state
C
(21-01-2025, 12:05 AM)Erich Wrote: Thank you, Chris. That's a start. But I don't know the specs. I think they are 7/32 so I think that would be a number 3. And I think the length is 1 1/4 inches, but since they are both buggered, I'm not exactly sure. As well, I don't know the diameter of the small end so unsure on exactly what I'm looking for...I've tried wiring the Austin Works at Longbridge and have yet to reieve a reply. ;-)
Erich in Mukilteo
You haven't read far enough down the thread Erich - according to Steve it's 7/32" x 1 1/4" (imperial type).
A possible supplier is also mentioned.
That is the correct specification, Chris. Important, as I said then, that the taper is Imperial and not Metric and for Imperial taper pins, the dimension (7/32") is taken at the large end. All the information needed to specify the correct pins is there already!!
