13-01-2025, 04:16 PM
A little collective advice needed.
A friend, who has run a Big 7 for years, has seen the light and bought a project Baby 7. The engine was apparently rebuilt but ran very noisily. We stripped it down and found that a new crankshaft had been installed but there were many problems with the engine assembly, including oval, oversize small end holes in the original, Austin rods, enlarged valves fitted without relieving the head, high lift cam without shortening the bronze cam follower guides, massive timing gear backlash etc.
The engine had been run, maybe 500 - 1000 miles but had obviously shown problems.
My friend removed the big end caps and has found that the hardening on one of the crank pins appears to have failed and the pin is pitted and slightly scored. This might be due to corrosion; the corresponding metalling appears OK.
So, the question is: Can we regrind the crank -0.010 and run it without the hardened layer? Has anyone done this? Could it be ground and re-nitrided?
The crank might be a Phoenix (it isn't marked as such) or might be one of Tony Betts.
Any thoughts, Ladies and Gentlemen?
