19-12-2024, 04:40 PM
Gearbox syncro confusion
19-12-2024, 06:20 PM
(18-12-2024, 06:03 PM)Parazine Wrote: I've found, over the years that the 4 speed crash box is actually the nicest to use - if you can cope with double de-clutching all the time The 4 speed synchro is very prone to baulking (i.e. the striking dogs meeting head on, preventing engagement) when the synchromesh is working and also prone to the synchromesh wearing out (which cures the baulking problem). The gearchange is also heavy and ponderous in my view. The crash box is a little slow but the change from 1st to 2nd is usually very slick and the whole unit is beautifully (and no doubt, expensively) engineered, with chevron gears, to cancel out the end thrust produced by the helical cut pattern. The crash box is light and easy to use, once you get used to it. Strangely I've enjoyed all the small Austin synchromesh gearboxes over the last sixty years. First car I drove was an A30 with 803cc and we never found any problem with it's original early 3 synchro 'box. Next was an early mk 2 A40 with the 948cc and the same type of gearbox. Again the gearbox seemed fine. Then an A35 with 948 and again that box was fine. Following on was my brother's late A35 van with the original 1098cc and presumably the later gearbox. Didn't notice any improvement in the gearbox. Then I had a later mk 2 A40 with the 1098 engine and gearbox. Again didn't notice any difference in gearbox. I also borrowed a 1275cc MG Midget quite a lot. The gearbox seemed no better or worse than the others. Now I've been driving my 1934 A 7 Ruby for nearly 5 years. Gear ratios seem odd but never a problem changing gears. The synchros are worn and it often need double-de-clutching, but that isn't a problem. I've never been aware of any baulking in any of these gearboxes. The first car I drove legally on the road was a 747 sidevalve Reliant with a four speed non-synchro gearbox. That was a challenge! Double-de-clutching was soon mastered but it was very difficult to always get it right. It seemed a tough but crude gearbox made by Reliant themselves. I never looked inside but I got the impression that each gearwheel was big, heavy, and very strong.
19-12-2024, 10:02 PM
Chris is correct, after removing the gearbox top a big hammer and bar put it back in neutral with the balls and springs flying everywhere, I then drained the gearbox and collected all the balls and springs and returned the oil to the box. The car park was at the bottom of a steep hill, the only way back, getting up which required balancing the amount of power versus my left hand holding it in gear. It was sometime before I had the box out and fixed it. That was in 1971, Peter Fearn suffered a similar failure going to Woolaton in 1991, and C Kingsford-Curram on the Alpine adventure in 1997.
20-12-2024, 10:13 AM
You did well to get it going Dave. In my case the sleeve had effectively "tipped" off the end of the shaft and no amount of levering and bashing would slide it back again. It finally came off when the gearbox end cover was removed.
I don't think this is a reason to spurn 4-speed synchro boxes, but owners would do well to have a look inside now and then & check for excessive play.
20-12-2024, 07:37 PM
(This post was last modified: Yesterday, 10:15 AM by Colin Morgan.)
Thanks - useful to know that end float was the problem - since this can be checked.
20-12-2024, 10:11 PM
I have nothing against 2 synchro boxes Chris.
Yesterday, 01:54 PM
