Cam Follower Question ???
Can a cam follower be replaced without separating the block from the crankcase ?
Guess the valve would need to come out though ?? Huh
You will need to remove the valve, spring, collets, cup and the guide - you may be able to pull the guide up to allow enough room to remove the follower, unless the cam follower guides have been cut down.
Do you have a split follower?
(18-12-2024, 05:08 PM)Ruairidh Dunford Wrote: You will need to remove the valve, spring, collets, cup and the guide - you may be able  to pull the guide up to allow enough room to remove the follower, unless the cam follower guides have been cut down.
I'm beginning to suspect that's the issue, the 'noise' seems to be coming from the valve train area ???
I'll get a chance to check after Xmas, when I've more time, but I've just been made aware that the cam follower guides 'may' need to be cut down a fraction if running reground followers and camshaft.
Is it perhaps possible to withdraw the followers downwards into the crankcase if the camshaft is first removed?
(18-12-2024, 05:52 PM)Chris KC Wrote: Is it perhaps possible to withdraw the followers downwards into the crankcase if the camshaft is first removed?
If it is a Cam Follower issue, and they can't be removed by Ruairidhs method, I'd rather lift the block upwards.
I have swapped out a number of can followers over the years, using the method above.
You don’t normally need to remove the block.
(18-12-2024, 06:31 PM)Ruairidh Dunford Wrote: I have swapped out a number of can followers over the years, using the method above.
What's the best way to draw up the valve guides , I'm guessing draw them upwards with studding and nuts ???
You can also drift it down the way, I presume it is parallel guide, and replace it that way too.
If you have reprofiled followers you probably will have to shorten the bronze guides,and certainly if running a reprofiled cam too.The tappet locking nuts foul them before the follower reaches the cam lobe.I did make and loan a tool to cut them down in situ many years ago.
Cheers Ruairidh & Austin , looking at the 'Build Sheet' it definitely states the cam was "re-profiled" & I'm sure , but can't find any reference to the cam followers either being re-ground/replaced ???
Also, when checking the noise from the valve area I found at least one valve with a gap in excess of 0.030". It was also fitted with a Silicon block/crankcase gasket, which I guess is much thicker than the paper gasket used in the past. Currently the car is not accessible, but early in the New Year I will rearrange the workshop and check , and report my findings.
Austin inthe Shed, what did this tool look like ? as I may be able to replicate, if ??? the bronze guides are too high . Cheers.
