SU needles
John,
what make of wideband sensor and display do you use?
Innovate Motorsports MTX-L. The kit comprises a sensor boss, a Bosch LSU 4.9 sensor and a dashboard display. I couldn't justify the cost for one car, but I am called upon to tune a variety of classic exotics (sadly I don't own them !). If your car is 6 volt you will also need a small 12 volt battery, the gauge and sensor draw about 1 amp.
It’s best if you get a heated lambda sensor - identified by 4 wires. Mine came from a scrapyard. You can read it with a simple volt meter.
Users browsing this thread: Parazine, 3 Guest(s)
