23-05-2018, 04:13 AM
On page 165 of A7 companion, in "Notes from a series of lectures by J. French on building a 750 Formula car" there is a para which reads as follows:
"It is a long time since I saw any new spares for the 1930 "screw-in" torque tube axle; later pinions are too short and I don't think a wangle is possible here. You can, however, change the entire torque tube assembly for any of the later types, which process, in effect converts the axle to '31 type. This enables you to use any pinion which has the bearing retaining thread."
Can anyone suggest what the second sentence means exactly and how it would be accomplished? I can't fathom how a bolt-on tube would be fitted to a screw-in casing without a fair bit of butchery; and if it in fact refers back to the 23-29 axle type, the 'nose' on the banjo is shorter. Is it just a mis-transcription?
