13-12-2024, 06:37 PM
I fitted a lip seal to the rear main since when it leaks like a colander, the flywheel boss runs true and is as smooth as a baby's bum and yes the oil thrower is fitted, so what is wrong?
Rear main bearing oil seal
13-12-2024, 07:57 PM
Happened to me once and the answer was as Alan suggests. From then, always fitted the boss with an appropriate speedi-sleeve and never had another problem.
13-12-2024, 09:17 PM
No it's within the size range for the seal
13-12-2024, 09:52 PM
Both of mine leak copiously too. Looking forward to the solution!
13-12-2024, 10:02 PM
Silly question- seal is the right way around ?
13-12-2024, 10:40 PM
Likely that the flywheel and seal plate are not concentric.
Also check the drain hole in the housing is in the correct place and not blocked with sealant.
14-12-2024, 12:30 AM
What possibly helped me, was to ensure that the crankcase was able to breathe (pipe connected to the oil filler tube that leads away to the side of the car) this seemed to take the pressure away from the modern lip seal/speedy sleeve arrangement (no oil thrower) and reduce oil leaking from the bell housing drain hole.
14-12-2024, 11:30 AM
14-12-2024, 03:16 PM
