An absolute bargain of a vertical miller for sale
The gentleman who ones this fine machine finds himself in a situation where he must clear the space that it occupies -  hence it's now offered for just £350 (and you might even obtain it for less).
I've put this on the forum first - before the advert is changed from £750 - so, if anyone would like to take advantage of this - get cracking!
For Sale: Hayes Diemaster Precision Vertical Milling Machine - a compact, high-class miller tool in full working order. Retrofitted with an infinitely variable speed motor drive. Table 21 x 6.5 inches. The swivelling vertical head has a No.2 Morse taper and fine down-feed through a worm-and-wheel gearing. Complete with a machine vice, an ER25 collet set and a clamping kit.  The need for the room is now beyond urgent and the price is now reduced to the staggering bargain of just £375 (currently listed at £750). Phone: 02392-823331 (Southsea).  Pictures of the Hayes Diemaster for sale here and details of Diemaster millers here.
What a superb machine at a brilliant price…but my workshop is already full!
That is a very good machine at a brilliant price.
And your choice to post it here first is admirable
Tony is it still available ?
Yes, as far as I know. I've only just relisted it at the lower price - so you might be in luck; phone now!
The owner is a lovely guy who has a car to restore and needs the machine out to get the car in. Another example sold for £750 a couple of months ago.
The spec is even better than first listed: Hayes Diemaster Precision Vertical Milling Machine - a compact, high-class machine tool in full working order. Retrofitted with an infinitely variable speed motor drive that gives both higher and lower speeds than the standard 50 to 2400 r.p.m. Table 21 x 6.5 inches. The swivelling vertical head has a No.2 Morse taper and fine down-feed through a worm-and-wheel gearing. Complete with a machine vice, an ER25 collet, clamping kit and a halogen light unit. Phone: 02392-823331  https://store.lathes.co.uk/adverts/for-s...ng-machine
Users browsing this thread: Tony Griffiths, 1 Invisible User(s), 3 Guest(s)
