Arriving back from a local trip the other day, I discovered that one of my rear lamp bodies had fallen off. It would be nice to source a matching lamp rather that spend a small fortune replacing both of them. However, I can find no identifying marks on them. Anybody recognise them? A bizarre question I know, but any help would be appreciated.
The bodies are brass and the outer bit screws into the bulb holder.
I have something which looks the same in a box of bits in the loft, albeit it's steel and missing its lens. Can you measure the diameter and length of yours and if this is suitable you can have it. Your next problem would be where to find a lens...
Good morning. There’s a lamp similar to yours currently listed on eBay. It’s listed as ‘Vintage rear lamp and number plate light Rolls-Royce.’
Unfortunately I’m not able to post a link.
