Car type: 1933 Austin Chummy
Thanks all.
I think I will drain and flush the cooling system and leave with an antifreeze mix
over winter. At least if we do get a few decent enough days it will be ready to drive.
Will also change all oils even though the rear axle and gearbox oils are fairly new.
The car cover I have is supposedly breathable but might try with a cotton cover inside it.
I have carpets on the garage floor, more to make it slightly more comfortable when
lying under the car, but point taken about bare concrete.
We have a cat, so no mouse problems. She does like to sleep in the car
when I leave the garage door open.
Looks like we have a few more fine days so chance of a few more runs, but will
start the winterizing later next week.
Thanks again,
Martin.
The cat asleep in the car…better than any trap!
I always blow the tyres up very hard ie 60 PSI
Make sure I have clean coolant (blue 50/50 with water) only lasts two years.
Low dilutions do not have the anticorrosion properties.
Fill petrol tank up to the top and put a dose of millers tanksafe in it.
Nick,
The fuel tank was something I was wondering about, already having had problems
with it.
I had not heard of the additive so will get some in the hope I do not end up with a 'bad' fuel tank again.
Many thanks on the tip.
Martin.
What a lovely shot, but I can’t help noticing how narrow that garage is!
There must be countless numbers of those narrow garages which were the latest thing in the 1930's to anyone buying a new house. My Father still has such a garage. It's just a nice size to park his mobility scooter !
