  • 1 Vote(s) - 1 Average
Uncoupled brakes conversion?
#31
It would definitely pay you to revert to the un coupled set up and if you could combine that with the bigger cast iron drums...and some good linings ... then assuming all the wear is taken our of the system, you should have more agreeable braking.
Indeed, a Seven properly set up should be a joy to drive.
