Car will only run on easy start... help please
(19-05-2018, 06:06 PM)John Mason Wrote: You learn all the time on this forum. What is Aspen 4T Akylate petrol.
John Mason
Very Expensive!
This stuff is designed to burn clean so that you are not inhaling so many toxins when piloting/following your mower.
Just put fresh, preferably premium unleaded in after a layup.
Thanks John. I think I will stick with what I always do. At the end of the season run it down to about a gallon then in the spring put a drop of new petrol in the carb float chamber and get the engine running enough to get things warm then down to the garage for a couple of gallons of new fuel.
John Mason
(19-05-2018, 08:45 PM)John Mason Wrote: Thanks John. I think I will stick with what I always do. At the end of the season run it down to about a gallon then in the spring put a drop of new petrol in the carb float chamber and get the engine running enough to get things warm then down to the garage for a couple of gallons of new fuel.
John Mason
Sounds like a good plan John Wink
