26-09-2024, 03:41 PM
Hi All
I’m getting a bit fed up with this van of mine!
On the ‘what have you done’ thread I mentioned that I pulled the centre stud whilst attempting to cure a leaking gasket. Well the stud was already a stepped stud so I made one with a lot more thread.
Before I install a new gasket I thought I’d torque it up against a tube to test it. It pulled again.
Closer inspection and I think the block is U/S. Hairline cracks from the stud hole to the liners.
So first question……I have a 1925 magneto engine that was running when I took it out of the car. I assume there is no reason I can’t use the block from this engine in the coil engine?
Second question…..If this is not possible anyone got a spare good block they could sell me?
