24-09-2024, 07:27 PM
The intermittent saga of Hilda the RP saloon continues...
The car had been fitted with a new floorpan when it was restored back in about 2005 but they hadn't fitted any bump stops, partly I suspect because the hydraulic brake pipes were in the way. I would now like to fit some, after first moving the brake pipes a bit and also relocating the handbrake mechanism which is mounted on top of the back axle centre case and is hitting the bottom of the car when going over large bumps.
One of the problems is that I don't know where the bump stops should be fitted – it's quite difficult to be sure of the correct fore & aft position by measuring up from the axle side tube. I would be grateful if people with an RP could tell me the distance from the vertical piece shown in the photo to the front fixing hole of the bump stop.
