9 hours ago
Spent much of the morning fitting the replacement oil pressure gauge (kindly supplied by Ruairidh) to the RP. Took the little car up to Llanuwchlyn (at the other end of the lake) to get animal food and brought it back down the A494 to Bala. All good, although the gauge appears to read a bit 'slow' compared with the old one. I am sure that I am pulling more that 1 lb sq in at 30 mph hot. the old gauge would read between 2 and 3 at that speed. However, I don't suppose that it has been fitted to a car for quite some time, so I shall run it for a bit and see if it 'comes to itself'.
