Car type: Seven Special
Hi Terry and all,
Can your recommend someone who can do this as you described? Most I've asked are only set up for 3/4 rad.
Thanks,
Paul N-M
Use 1.6"radius for all followers as no one does asymmetric anymore as they are not cost effective, try Paul Bonewell or David Dye. Terry.
Thanks Terry,
Dave Dye can only do 1.2" and I'm waiting for more info from Paul Bonewell. I did not explain I was using a Newman cam so hopefully Paul can help, fingers crossed.
They are aluminium with steel caps, intended to reduce weight and valve bounce in a high rpm race engine. I have not personally gone down this route so cant comment first hand on their effectiveness, although I have heard claims of success.
