Hi,
Does anyone know what thread is on the wing screws that hold the opening windscreen in place.
I believe they're probably 5/16 but I've no idea if BSW or BSF.
John.
Sorry, probably didn't explain very clearly.
I haven't actually got the wing screws to measure but as I'm about to make the barrel nuts they screw into I need to know what thread they should be tapped.
John.
The thread is normally 5/16 BSW.
There is more tensile strength in a male BSF thread than in a BSW, but the BSW thread itself is stronger and will better resist getting stripped.
