09-09-2024, 10:01 PM
Set every block stud in place with Loctite, then they won't leak. Plus you can remove them easily if need be.
Coolant leak from manifold studs
10-09-2024, 12:27 AM
(This post was last modified: 10-09-2024, 12:28 AM by FrogPond.
Edit Reason: add a name
This. Thread Sealant. Just seals them, doesn't lock them. Mike
10-09-2024, 07:36 AM
Hi
I had leaking manifold studs. Permatex thread sealer used. They no longer leak.
11-09-2024, 03:55 PM
Have now removed the manifold and studs which were all replaced during recent rebuild. No real issues other than one stud came out along with the helicoil and one had a chewed thread for some reason.
So new studs, helicoil kit and Permatex (thread sealer I already had not high temperature) on order! Will update once all fitted................. |
