Hi All
On another thread there is mention of the cotter pin that holds the kingpin tight in the axle eye. It is contrasted to the cotter pin that ‘say’ secures the crank on a bicycle.
Is there a correct definition for the two types? Half moon and wedge have been used. Austin refers to both as cotters. A Google search provides no answers.
Half moon and wedge is correct.
Other names will exist.
Car type: 1932/3 AH tourer
Is not a 'split pin' also technically called a 'cotter pin?'
Car type: 1934 Austin Seven box saloon
I think 'cotter' can refer to a variety of locking devices. I work on rail wagons and we have cotters that are a roughly 4 x 2" rectangular plate passed through a slot. Bit off subject but there you are
My dictionary defines a cotter as a pin or wedge passing through a hole to bind parts tightly together. That definition appears to cover a multitude of fixing devices.
It appears, however, that the Americans use the term to mean a split pin. I am reminded of the 'bon mot' attributed to the late Sir Winston Churchill describing the English and Americans as " two nations divided by a common language"
I've always called the brake pin type "taper cotters"
