Good evening all,
Can someone please tell me when shell bearings for big ends came in. My engine no is
M278745 and I should like to know whether it’s a late enough engine to be fitted with shells.
Thanks,
Charles
According to the A7 Companion, shell bearings were fitted from engine no 268659 in March 1937.
(However, my engine M289617 has non-original white metal bearings following an engine rebuild sometime in the distant past - so engine number may not reflect what is in there.)
Colin
Yes, I managed to take out and later refit a remetalled No 3 con rod without removing the engine. However, I think I was lucky that the crank journal was serviceable - hardly marked and within the (couple of thou?) ovality limit. (Getting a series of accurate micrometer measurements upsidedown in the confines of the crankcase took a bit of practice.)
Colin
I've changed both big end and centre main shells from underneath, it's quite do-able so long as no damage on crankpins needs rectifying. Not much to lose though - in that case you still have to take the engine out but it's drained and the sump's off already.
Car type:
Could I ask whether shell bearing conrods are any use for retrofitting on earlier 2 bearing 1 5/16" engines?
They aren’t really interchangeable. I’m not saying it’s never been done but 3brg rods are offset slightly to compensate for the different big end journal spacing. ( needed to get the centre bearing in)
