13-07-2024, 06:31 PM
Long overdue store blitz make available;
early coil engine, c/case no M13335
late coil c/case, good teeth for starter
magneto crankcase, manifold for updraft, block with valves
3 speed box, spare cover
PM or stevekaytwo@btinternet.com
all be be collected from Abergavenny, swapped about 25 mile radius or Chateau Impney car park, also numerous crank shaft, pistons, coil engine dynamos, lots of kit far too good to weigh in, is there a club shed closer than Bristol or should that be the fall back destination?
