Buy some 8.8 or 10.9 bolts and applicable nuts. Say 6mm or thereabouts. They wont strip then. They'll do up 'FT' no problem
I have a lot of old R BSF/BSW bolts and are distinctly more strong than mild steel. I understood it to be the standard hardware HT. Does anyone know just what standard was/is the basis? A 1969 publication seems to imply S only for UNF/UNC and slightly more strong than R. Obsolete standards are a problem as anything can be claimed, as with API SF, SG, SJ etc engine oils.
Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
I used 8mm as that was the size of the rivets, remember the Rosengart is the same as an Austin but different.
Basically, you don't want the bracket to move. It can't fall off and the bolts are in shear, so they really don't need to be "over tight". As others have said, quality material and out of preference nylock type nuts.
