29-04-2024, 09:19 AM
Good morning chaps,
Monday morning question really, over the weekend I had limited time in the garage, I'm in the process of removing the flywheel to change the rear seal, something is clearly missing or wrong as it leaks very badly. I plan on buying a modern seal kit, however looking through my spares I found the Aluminum plate used for a modern seal (I guess). Does anyone know if the seal is available, the seal part number or size as Id buy one to have for a future engine build. Or I can measure both the plate hole and flywheel boss I guess ! ....
I'm right in thinking this is a bolt on modification ? is there anything else I need bear in mind ...
Many thanks in advance Matt..
