13-03-2024, 08:15 PM
I'm in the middle of a partial engine overhaul at the moment.
The timing gear pair (presumed original to the crankcase) has about 10 thou backlash between teeth and the teeth are slightly pitted but I have seen worse. The gears and crankcase are stamped + 1/2. Cam gear fore-aft backlash is about 4 or 5 thou, and the bush and square headed peg bolt are good.
Anyway, the plan was to replace said gears with a nice new cast iron set from Dave Dye, which is sitting in wait.
Woodrow says "Using an extractor, remove the pinion from the camshaft" - if only !
I have modified a strong extractor which has two bolts going through the holes in the web, and uses two blocks which bear against the back of the web (The boss is rather hard to grip). With this extractor wound up as hard as I dare, I have heated the boss with an admittedly small blowtorch and administered blows from a hammer and brass drift. This has resulted in no perceptible movement of the gear whatsoever. If I didn't know better I would swear they are welded together
I do worry about the thinness of the web and the fact that it's cast iron, otherwise I might take it to an engineering shop and get them to use their hydraulic press
In extremis I suppose I could destroy the original gear, but I'm very reluctant to do that.
Any suggestions ?
Any suggestions ?
