06-03-2024, 10:24 PM
Hello All,
Always seems to be plenty advise on rear springs out of the chassis - it varies from don't do it, to get it done because the handling and ride will be so much better.
I now have the first spring off the car - please don't ask.
I was surprised to find a "packing piece" about 6 inches long below the spring inside the chassis frame. Research shows that this packing piece shoud be A7 Spare Part BR81 .. The car being a long-wheelbase Box Saloon
My question is does anyone have the correct dimensions for the BR81 (length, Width, thickness). The width should be the same as the spring. The position of the hole in the packing piece, which I assume aligns with the main front bolt of the spring, would be useful.
Of course I would need the measurements if someone has a boxful on a shelf somewhere!!!!
Any help gratefully received.
Old Dave
Old Dave
