Hi Austin. My bulkhead is tight against the back of the engine but luckily the column will just fit. Perhaps the dimensions given in the instructions are a shade longer than original. I bought the kit in the 80's as I recall. Since there wasn't really any alternative it's all good....just a bit frustrating at times.
Looks like 3" to me, that was the dimension I used on the cars I re-built. I found that Austin seemed to have a habit of using whole numbers with sensible 1/2" and 1/4" etc. where possible but I may be mistaken in thinking it was deliberate policy?
I for one appreciate the shot of the Lotus, I forget how many I have had in bits/repaired/repainted over the years, I’d have another today, but I think I’d do myself an injury getting in and out these days!
Excellent work on the van.
Is that a Judson blower on the MGA's motor? They're not common 'over here' saw a similar blower setup on a VW Beetle years ago.
Thank you Stuart.
Yes it is a Judson supercharger which in this case is for the MGA. They used the same unit only in different lengths for the likes of Renault, VW, BMC A and B series, Triumph etc, all with a total loss lubricator. The lubrication oil is Marvel Mystery Oil which is the same as Redex as far as I can tell.
Cheers,
Stephen
Hi Steve
I am very much enjoying your van build. Thank you for taking the time to post the excellent photos.
With regard to the steering column clamp, I seem to recall that on my RK the fuel tank support uses the same hole as the left hand one on the steering clamp. Could there be some discrepancy with the position of the tank or the mounting holes on the dash?
Thank you Howard. I'll check to see if my tank will allow me to do this. I have an Idea that should work if it doesn't.
Stephen
