  • 1 Vote(s) - 4 Average
Vacuum Wiper - How to connect to inlet manifold, where to put the vacuum pipe
#51
Linseed oil was the basis of paint and dries to a varnish. Would seem completely unsuitable. If it rains in Germany I suspect you will soon return to electric.
Hello Bob,
that was excactly what came to my mind when I read about the linseed oil. I used linseed oil for my oil paints and if the linseed bottle had not been in use for a while opening it was nearly impossible because it had become hard. Other vegetable oils, as suggested by the company that sells the seals, possible?! I do not know.
Concerning the weather. If it rains my car stays indoor... have been doing this for the last thirty years. Of course the weather in the southern parts of Germany is pretty hot and dry. Even today we had temperatures beyond 30°C and I took my Austin on a 97 miles tour through the lovely (unfortunately dried out) forests of southern Germany. One drop of rain (well... slightly exaggerated) and the car is off the road.
Frank
The springs of the Citroen 2CV operate inside a steel cylinder. The pull rods which act on the springs have a leather washer similar to the vacuum wiper but much bigger. The washers trap air between the two springs which acts as a suspension damper.
On the 2CV springs the washers are lubricated with castor oil or vegetable cooking oil.
Hello Jim,
thank you for your answer. The two options for the Citroen (Germans pronounce it Zitrön and I think the company has changed the pronunciation in their commercials as well.... ) do make sense. The option using Castrol oil at least does not turn rancid, something I would not like to have in my car... Smile
Thanks for your answer
Frank
This post must have set a record fro length/substance!
I have one probably off an RP. It has a little hole in the top leading into the cyl chamber and is labell "use thin oil"..
Hello Bob,
exactly. A tiny hole for little amounts of oil. When I saw it, my first thoughts were: "How often? How much? What sort of? Necessary for the mechanical parts (metal) and also for the leather seals?"
I came to the conclusion that seals would get in contact with the oil only at the bottom, provided that the oil does not drip out at the bottom of the wiper motor simply because the whole thing is not a perfectly closed system (no need for, anyway). I think I will go for the "Castrol solution". Good for the mechanical parts (metal) no potential threat for the leather washers. As soon as the washers arrive, I will show the results and failures! in detail.
Frank
I was always taught that with oil you use mineral on mineral, vegetable on vegetable, and animal on animal. So mineral on a bicycle, linseed on a cricket bat, and neatsfoot on a horse harness. The best thing for your new seals would be soak them in neatsfoot oil, though whether it is worth several pounds for 500ml. (plenty on Ebay), is up to you.
Cliff.
Hello again,
after about 10 days the leather seals arrived (CP 630 Pump Leather, www.base-camp.co.uk) and I have taken some photos to give you an impression. The outer diameter is perfect. The seals fit into the tubes and can be moved. No gap. The height and the inner diameter are the two things that slightly worry me. The smaller inner diameter means that the metal washer inside the original seal (bigger) would press the new seal apart and therefore widen the seal. I think a smaller one has to be made... should not be a real problem. The height could cause some trouble, simply because it might collide with the oscillating valve assembly. We will see. I will keep you updated.
Frank
[Image: Manual_Lucas_Wiper_Motor_003.jpg]
[Image: Manual_Lucas_Wiper_Motor_003e.jpg]
[Image: Manual_Lucas_Wiper_Motor_003c.jpg]
[Image: Manual_Lucas_Wiper_Motor_003d.jpg]
That doesn't look like the right washer Frank, the Riley Register Spares limited sell the correct ones.
http://www.rrsl.co.uk/product/lw1-lucas-...on-washer/
However, looking at your original it looks in good order.
Thank you Dave,
they seem to be the right ones. Will order them at once. Thank you for the link. The old seal which you see in the photo is the better seal, the other seal is torn and leaky. Kind regards
Frank
