19-05-2022, 06:50 PM
Thanks Jon - I will add that into the mix. I have been told, from one source, that the plates were originally rivetted, so that adds weight to your suggestion of originality.
Patent Plate Minutiae
19-05-2022, 07:26 PM
19-05-2022, 07:32 PM
19-05-2022, 09:57 PM
Thanks Ivor!
20-05-2022, 10:28 AM
This 1923 car (A1-1658), and a couple of others with decent pictures on-line, do not seem to have patent plates fitted. (However, , cannot find a good on-line picture of a 1924 patent plate - they were sited low down behind the steering column and are often partially obscured.)
20-05-2022, 10:46 AM
Thanks Colin...
I am still in need of the run through the 1930s that are seemingly proving elusive to track down. I am particularly interested in a point when the larger plate moved to the smaller plate. I dont think it coincides with the introduction of the Ruby, but I would like to be able to prove it...
20-05-2022, 12:42 PM
Hugh, the change from large to small plate did not coincide with the introduction of the Ruby. I don't have pictures, but my (early) 1936 Ruby, (late) 1936 van and (early) 1937 Ruby all had the large patent plate. I believe the smaller plate came in quite late, maybe mid-1938, but someone will have the answer.
20-05-2022, 12:48 PM
Agreed, my March 1936 Ruby had an original large plate.
This would eventually make a nice pdf document like the one that Frank Stoll has done on RPs.... a Minutiae series!
20-05-2022, 01:05 PM
(This post was last modified: 20-05-2022, 01:07 PM by Hugh Barnes.)
yes John..
