I have no idea what happened to my father's crankcase. I think it arrived with some other bits and pieces, but wasn't of much interest except as a curio.
I sailed on a ship whose lifeboat had an A7 marine engine, with a chain-drive starting handle. I don't remember ever trying to find out the material of the crankcase. I do remember it was painted though.
My Thetis marine engine had an aluminium crankcase, although the whole engine was covered with a red paint not unlike red oxide but thicker and tougher. I thought this may be some sort of protection from water damage.
As an aside, the late Arthur Davies had a cast iron crankcase which he painted with aluminium paint and stood on the end of his stalls. He always enjoyed customers picking it up to ask the price !
Car type: 50s race car.32 trials car
hi. all .chris gould thinks it might have been used as a generator set in a tank ?? only what he heard
28-01-2021, 05:47 PM
(This post was last modified: 28-01-2021, 06:21 PM by Jeff Taylor.)
Certainly the 1930's Morris 8hp side-valve engine or to be more specific the 1948 to 1953 Series MM Minor almost identical variant was used to power a generator in the Army's Centurion main battle tank. Back in 1989 I bought a complete wooden crated N.O.S Morris 8hp Centurion tank engine direct from Army stores - they were always painted in the Army's traditional armoured vehicle engine colour of duck egg blue. I believe there's lots of spares still around in Australia for these Morris 8 engines as the Australians bought the British Centurion Tank for their armed services.
Like a number of others on here, I too have what appears to be a N.O.S (short) RP cast iron nosecone which I picked up on eBay many years ago for very little money. I thought it might come in useful for my 1934 Van restoration. I'll dig it out and see if it has any numbers cast into it.
Hi Graham,
A tank sounds good, if anyone is in contact with any of the countrys excellent war or just tank museums may be able to confirm it.
I now most if not all of the boat and pump engines were aluminium. As were the military car engines.
This is only my guess to there use, and the reason they are put down as military. Is the they were running as temporary or portable light generator.
The army and air force, would both have a use for this application. Why make them in cast iron? If you have a set of spot lamps hanging of a long pole. You need a heavy base unit???
Tony.
hi all.do you think it would make a good 3 bearing race engine for my car ? if it was a prototype or out of an mod unit. i would have let someone restoreing one have it .for what i paid for it a long time ago.i do not want to race and distory a pice of austin history
As noted by Charles. Itll make the front of the chassis very stiff if thats what you want.
On the other hand itll be heavy
You'll need to drill it liberally before it would be light enough to use in a racing car!
hi all. dose anyone build 3 bearing race engines? who is the best?my race car has cooper front end and rad behind driver. so i think extra revs from cast bottom end might give more power ?
