12-11-2018, 09:27 AM
I still find it extraordinary that the last bit stays together!
The symptoms of a 3 bearing crank failure?
12-11-2018, 09:44 AM
(11-11-2018, 05:30 PM)Chris KC Wrote:(11-11-2018, 02:07 AM)Bob Culver Wrote: The centre bearing of the Seven dangles from the thin roof of the alloy crankcase so deflection under load must be significant. The mountings are frequently distorted out of static alignment which makes matters worse. Have used valve springs under tension to replace fixed bolts for many years — an improved oil feed to the centre main in conjunction with an oil filter is a feature of most engines assembled by Vince Leek and seems to make sense. Charles
12-11-2018, 01:36 PM
12-11-2018, 02:05 PM
(10-11-2018, 12:44 AM)Tony Press Wrote: Our Club Secretary had a comprehensive engine failure with a Club three bearing crank when returning from a Club run earlier this year. The faiilure is through the rear web.Isnt that a 2 bearing crank in a 3 bearing case with the middle bearing hacked out?
12-11-2018, 02:24 PM
(12-11-2018, 02:05 PM)Hedd_Jones Wrote:I think you're right Hedd(10-11-2018, 12:44 AM)Tony Press Wrote: Our Club Secretary had a comprehensive engine failure with a Club three bearing crank when returning from a Club run earlier this year. The faiilure is through the rear web.Isnt that a 2 bearing crank in a 3 bearing case with the middle bearing hacked out?
12-11-2018, 05:48 PM
12-11-2018, 07:54 PM
RAt least the failures are consistent - exactly the same failure as mine.
What did you do to repair Alastair?
12-11-2018, 09:04 PM
'What did you do to repair Alastair? '
I think I personally am beyond repair ![]() Good luck with yours Alastair
12-11-2018, 10:36 PM
(12-11-2018, 02:05 PM)Hedd_Jones Wrote:(10-11-2018, 12:44 AM)Tony Press Wrote: Our Club Secretary had a comprehensive engine failure with a Club three bearing crank when returning from a Club run earlier this year. The faiilure is through the rear web.Isnt that a 2 bearing crank in a 3 bearing case with the middle bearing hacked out? The original three bearing crankcase was a little far gone to 'hack out the middle bearing' so he replaced it with a two bearing crankcase and new crank. ![]() ![]()
12-11-2018, 11:33 PM
(12-11-2018, 10:36 PM)Tony Press Wrote:(12-11-2018, 02:05 PM)Hedd_Jones Wrote:(10-11-2018, 12:44 AM)Tony Press Wrote: Our Club Secretary had a comprehensive engine failure with a Club three bearing crank when returning from a Club run earlier this year. The faiilure is through the rear web.Isnt that a 2 bearing crank in a 3 bearing case with the middle bearing hacked out? He had a two bearing crank before it broke |
